higher mileage 7.3 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-06-2014, 01:57 AM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
higher mileage 7.3
Looking at buying a higher mileage 7.3 power stroke wondering what things I need to pay close attention to.
04fording is offline
post #2 of 9 Old 02-06-2014, 03:04 AM
Check blow by , injector condition, and transmission.
Power-Struck dot com
POWER-STRUCK is offline
post #3 of 9 Old 02-06-2014, 04:18 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check turbo for pitting and shaft play, oil fill flip cap test, oil/Trans/fuel leaks, fluid in the valley
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 9 Old 02-06-2014, 07:38 AM
Quoted: 75 Post(s)
Check cold start and hot start, crawl up underneath and check for leaks and if its a dual tank truck make sure the selector works.
For higher mileage i'd already set aside $1k for maintenance, fluids, sensor etc. EBP tube is most likely clogged, fuel bowl will need cleaned out, possibly new T-stat if it doesn't warm up and so on.
White95f250 is offline
post #5 of 9 Old 02-06-2014, 04:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
All psd's have dual tanks
FYI I bought mine just north of 300k miles drove it across country
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 9 Old 02-06-2014, 06:51 PM
x2 on the cold start, I tell sellers if the trucks warm when I get there Im not going to buy it, also Check fan for play.
Bought mine with 440K and 1 year later its worked pretty hard and has a 450k miles on it. Still gets 21.5 mpg on hwy, and 17-18 in town. Best $1800 I ever spent.
94.5 F250 Extended Cab 5 speed 4x4 7.3 Powerstroke mostly stock
450k Miles
I build custom handmade guitars
jeff power is offline
post #7 of 9 Old 02-06-2014, 07:17 PM
the first thing I would do is tell the seller to not start it before you come to check it out, start when its cold you will know if you have bad injectors glow plug bad compression air in fuel lines thats not that common with earlier psd's but, than let it worm up and take it on a test drive shift trough the gears on the tranny if its auto and make shure the tranny works well than take it on the highway it should be smooth and half good power, than come back and check underneath for leaks and obviously check for blowbye and check the oil and tranny fluid, listen to the idle carefully it should be smooth and crisp and constant you don't want a loper
'97 F-450 XL Super Duty 7.3 PSD 11" flatbed AFE Cold air intake 3" downpipe to 3" stack soon to be 5"
'96 F-350 XLT CC DRW 7.3 PSD stock for now 225k mi
'95 F-350 XLT CC DRW 7.3 PSD Ranch hand legend front bumper 9" utility flatbed w/ head ache rack, stock 250k mi
'94 Econoline E350 7.3 IDI N/A 345k motor rebuilt, travel van
'86 F-250 HD XLT 4x4 6.9 IDI N/A, ex cab long box 33" mudders 200+k mi
'91 bmw 525i sedan 2.5l inline 6 cyl 240k mi
'86 land cruiser 4x4 #two
97F450SuperDuty is offline
post #8 of 9 Old 02-06-2014, 07:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You sir have a lot of ford diesels, and a very low post count
Btw everything in the previous post is a great idea
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 02-06-2014, 07:58 PM
Quoted: 75 Post(s)
Sorry had a bald moment, what I was thinking and typing didn't quite make sense.
