Turbo Help... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-05-2014, 05:24 PM Thread Starter
Turbo Help...
Well, upon trying to taking the turbine housing apart I chipped this connector housing (don't know the exact name). Any options on getting the bastard off the turbine housing (exhaust side). Also, where to get the new part or possible fix...
Thanks in advance, I replies will be appreciated.
T0RCH3D is offline
post #2 of 8 Old 02-06-2014, 03:28 AM Thread Starter
Anyone...?
T0RCH3D is offline
post #3 of 8 Old 02-06-2014, 04:03 AM
d7es3l's Avatar
You need a wedge. My buddy did the exact same thing & couldn't find a center housing so he had to buy a new (used) turbo.
d7es3l is offline
post #4 of 8 Old 02-06-2014, 04:35 AM Thread Starter
There is no salvaging the housing or finding used? Using a weld or something on the housing a possible fix, just trying to brainstorm as a new turbo is not what I have in mind.
T0RCH3D is offline
post #5 of 8 Old 02-06-2014, 04:41 AM
d7es3l's Avatar
Now I am not saying you couldn't find one used! He tried to weld it together but it didn't hold. He just didn't have the time to try to find a used one, so he bought a used turbo. Now if you have time to look for one & let your truck have some downtime. I'm sure you can find one.
d7es3l is offline
post #6 of 8 Old 02-06-2014, 04:59 AM Thread Starter
Damn that's a pain in the ***, I used a wedge and a pry all the around with no luck and probably used more force than I should have, still not getting it off. Any other options
T0RCH3D is offline
post #7 of 8 Old 02-06-2014, 07:44 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Don't think I have ever seen one so stuck. With all 4 bolts out of the turbine housing clamp the turbine to the table at the collector port (flat side). then twist the center section about half an inch back and forth. once it's moving just pull perpendicular to the housing and the two will, eventually slide apart. Soot gets in between the heat shield and center section (inside the turbine) and "glues" the two parts together. I've used a strap wrench on the center section before.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 8 Old 02-06-2014, 09:43 AM Thread Starter
I tried working my way around it and lightly tapping and nothing budged. It's like there is a heavy duty adhesive holding it together. Is it possible to get the turbine shaft out before the center housing comes out? I don't think it is, but I figure I'd ask. This thing is really on there, which sucks. I feel like I am going to mess up the shaft trying to get it apart.
T0RCH3D is offline
