Wheel well side box? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-05-2014, 09:16 AM Thread Starter
Does anyone have wheel well tool boxes in a shortbed truck? I need a little storage, but still need to get a full load of wood or 4wheeler in the bed. I'm just trying to figure out my options.
SlimMech is offline
post #2 of 11 Old 02-05-2014, 09:36 AM
Heavy_GD's Avatar
Quoted: 1576 Post(s)
Feedback Score: 3 reviews
Not sure what your budget is, but check these out: Swing case
GD
Heavy_GD is online now
post #3 of 11 Old 02-05-2014, 07:29 PM Thread Starter
Right now my budget is $5 . I did look at those, I'm just wondering how much room there is between them if there is one on each side and if they will stand up ok without a bed cap over them.
SlimMech is offline
post #4 of 11 Old 02-06-2014, 03:28 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Stand up to elements? Looks decent enough
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 11 Old 02-06-2014, 04:27 AM
Heavy_GD's Avatar
I had mine lined like the bed so they are tough and I run a truxedo cover.
The selling point for me is that they slide off the hinges and you can remove them when you need space.
Or you can remove them and they double as coolers.
GD
The Following User Says Thank You to Heavy_GD For This Useful Post:
SlimMech (02-06-2014)
post #6 of 11 Old 02-06-2014, 07:27 AM Thread Starter
Thanks for the input, I they do look like the way to go.
SlimMech is offline
post #7 of 11 Old 02-06-2014, 07:49 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
Can they also slide straight out instead of just swinging out? Or open while in the swung in locked position? They'd be useless with the bed full if not. Just, another thing for you to think about. lol
johnnybgood is online now
post #8 of 11 Old 02-06-2014, 08:12 AM
Heavy_GD's Avatar
no sir, they are swing only.
You can open them in the "locked position" but remember they are tucked under the bed rail.
Right, bed full they are stuck. Thats why if I have a load in the bed I take them off (they slide up and off the hinges) and set them in the bed or in the cab.
This is an alternative to a tool box, and more for a "weekend warrior" with a bed cover or a lifted truck so you can access them from the tail gate.
I wouldnt consider this for hard core work trucks that need a "real" tool box.
GD
post #9 of 11 Old 02-06-2014, 03:14 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Those seem the way to go honestly, seeing them in yours they look pretty good, and I like the cooler aspect what are they made of btw?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 11 Old 02-06-2014, 03:36 PM
ZMANN's Avatar
Quoted: 1668 Post(s)
get real your 5 dollar budget gets you this
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
Heavy_GD (02-06-2014)
