Injector O Ring Replacement Problem - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-02-2014, 09:07 PM Thread Starter
Quoted: 7 Post(s)
I am replacing Injector O rings and found what appears to be water / coolant on the injectors when I pulled them. All 8 injectors looked like this see pictures. Truck was running and has 260K on it. Is this normal or is there a bigger problem with this truck?
Name:	Nasty Injector.jpg
ID:	237218   Click image for larger version
Name:	Nasty Injector 2.jpg
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #2 of 13 Old 02-03-2014, 12:10 PM
Micko's Avatar
Quoted: 4 Post(s)
Looks like an injector cup issue, any oil in the antifreeze? What does the oil look like?
Micko is offline
post #3 of 13 Old 02-03-2014, 12:56 PM Thread Starter
Quoted: 7 Post(s)
oil looks OK no signs of water on the dipstick and when I drained the high pressure rails the oil was just black nothing milky. the coolant is green and at the right level and it smells like antifreeze not fuel. the only place there are any signs of milk is right between those 2 O rings. I was thinking injector cups as well but I thought it strange that all 8 were the same. I didn't think all 8 cups would fail at the same time.
post #4 of 13 Old 02-03-2014, 02:40 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Head gasket maybe? Im at a loss
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #5 of 13 Old 02-03-2014, 04:08 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
doesn't look good. oil cooler failure, but again oil would be in the coolant or vice versa. really really aerated oil?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 13 Old 02-04-2014, 06:16 PM
I would replace all the cups.
JTWAT is offline
post #7 of 13 Old 02-05-2014, 08:03 AM Thread Starter
Quoted: 7 Post(s)
I am glad it's not my truck. I guess I get to go and buy a set of cup removal tools. I hope that I don't run into this when I go to put in my stage 2's next month.
Can all 8 of the cups be replaced in the truck or will I have to pull the hear or engine to get to #7 and 8?
post #8 of 13 Old 02-05-2014, 07:47 PM
Micko's Avatar
Quoted: 4 Post(s)
You can get at them all but you'll have to take the heater box off on the passenger side. But, not sure I would go ahead and do it without a better diagnosis. I would expect to see a better indication like oil in the antifreeze etc. Could be the cups but not sure I'm convinced yet.
Micko is offline
post #9 of 13 Old 02-08-2014, 11:53 PM
What's the history of the engine? The grey keerap looks odd as there is no black engine oil mixed in. And it appears there is none on the injector oil deflectors or valve train? Seems odd that all 8 cups would be leaking at once with relatively low miles. Wonder if there was a recent repair to the oil cooler? Pull the bottom rad hose or open the rad drain to see if same stuff is there? Same with oil filter?
J
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #10 of 13 Old 02-09-2014, 12:02 AM
Rodslinger's B1TCH
the oil in your high pressure rails was black
your coolant is green and healthy looking
the truck was running good
i am going to say that some condensation formed in there between cold diesel, warm oil, cold coolant? was it started up cold, driven into the shop and shut down right away?
if it was me, i would continue like i never saw anything
steve604 is offline
