2 Bolt Superduty starter on a '97? Mounting upside down? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-02-2014, 07:14 PM Thread Starter
Today I did the third trial fit of my 1997 PSD in my Dodge Durango, the first fit with the full drivetrain after the body lift. I'm coming up a little short on clearance, particularly around the starter. It got me wondering, do the 2 bolt SD starters fit? They seem to have the same bolt pattern and appear to be a little smaller in size, which I could really use. The most clearance would come from mounting the SD starter upside down, but will it fit? Anyone know? Right now my starter solenoid is touching the frame rail. It looks like I may need to add another inch to the body lift to gain a little clearance for my hydroboost as well.
B.Reilly01 is offline
post #2 of 2 Old 02-03-2014, 03:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Not sure how much smaller but the 2 bolt starter will bolt rite up
Show piks of your swap progress
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
