95 f250 front end? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-02-2014, 05:51 PM Thread Starter
95 f250 front end?
hey guys im picking up this 95 f250 5spd powerstroke but it needs some work. now he says he hit a stump and bent the front end. now i can buy the truck for $1400, my my question is, are the front ends on the 250 a twin I-beam? can i repair this? or skip it and put a D60 solid axle in? and what work is required? or just post what you think is the best idea! thanks in advance!
jt1500 is offline
post #2 of 10 Old 02-02-2014, 06:06 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Yes they are the twin I beam would be better off to out a d60 in it. Work nvolved is go through axle end to end and check over rebuild so you don't have to worry about it might have to regear to match. If you have all the parts springs hardware brake lines everything you could possibly need it take a few hours to swap out. I had the ability to take all the time I needed did in a weekend picking up a few little items as I went. Mine will get alignment tomorrow. It's pretty easy if you have the ability to do the work yourself. Also note the front drive shaft from a tin I beam will not fit a d60 I had mine shortened 1 inch to fit. Some will say you need a f350 with double cardine joint you don't need it might be better but not necessary I'm going to compare since I have obs of each way
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 10 Old 02-02-2014, 06:54 PM
sethc24's Avatar
Dana 60. You wont regret it.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #4 of 10 Old 02-02-2014, 08:49 PM Thread Starter
thats what im thinking, now is there a list of what i will need to do the D60 front swap? and/or things to check over?
also by the pictures and price above do you think its a "good deal"
jt1500 is offline
post #5 of 10 Old 02-03-2014, 04:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Great deal there, go d60, you need trac bar, trac bar mount, springs, axle, steering linkage, pitman arm, and calipers (if equipped with slide pins) good luck
Do not forget to get the u bolt plates too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 10 Old 02-03-2014, 08:52 AM
You must be from Kelowna area?
96 F350 CCLB 4x4 7.3- Chipped, Turbo-back, Intake, Gauges.
Tows my Lsx swapped Volvo 240 and 240 turbo drift missile.
93 Subaru Legacy turbo wagon daily.
DevC is offline
post #7 of 10 Old 02-03-2014, 01:59 PM Thread Starter
thanks guys, i am still looking into the truck.
i am from vernon bc
jt1500 is offline
post #8 of 10 Old 02-03-2014, 02:20 PM
Sam Burton's Avatar
Hey I am in Armstrong, if you get it and need a hand I might be able to help you out.
I have done a couple Dana 60 swaps.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #9 of 10 Old 02-03-2014, 03:01 PM Thread Starter
well thanks lot for the offer! i shall keep everyone posted.
my best friend and i are going in on it together and i will probably buy his half out since i dont have a diesel and he is running an '02 7.3 with a 10" lift on 40s
jt1500 is offline
post #10 of 10 Old 02-05-2014, 07:09 AM
I was looking at that truck also for parts. If you are thinking about buying it the cost of a dana 60 with everything you need 1000-1500. It's also an icbc writeoff so complete inspection and re vin. It would be cheaper to buy a truck that is aleady on the road and insurable.
crazyjay is offline
