Boost Gauge Flutter - Ford Powerstroke Diesel Forum
Old 10-19-2008, 11:20 AM
Boost Gauge Flutter
My Boost gauge, since I installed it, has always fluttered. I drove a buddys 6.0, and his aftermarket boost gauge was smooth, and swept across the gauge.
How can I fix my gauge that is on crack?
I doubt any of the line is leaking, but I will put some water on it and check.
If it is something like a slight leak on an up pipe, would a pressure snubber work?
Thanks
Old 10-20-2008, 02:11 AM
you can buy a snubber that goes in line and will kill the flutter. That's what I did. I probably have a part number around here somewhere but I think I called autometer and they sold me one. Mine used to dance like crazy when I'd get my boost up in the twenties...now it's smooth all the way up.
Old 10-21-2008, 06:03 AM
made by chemquip products phone number 201-868-4445/6
porous metallic element pressure snubber
stainless steel, size 1/8 npt, catalog no. 12s, porosity E
It worked for me. if you can't still buy it through autometer then you can call chemiquip directly I would assume
Old 10-21-2008, 11:33 AM
Thanks Darth Stroker!
