97 f350 obs injector in 95 f350? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-02-2014, 08:11 AM Thread Starter
Curious.. What would most likely occur if you put 1 injector from a 1997 f350 7.3 obs into a 1995 ford f250 7.3 obs. Saying both are not ca trucks. Good or bad?
EdotF is offline
post #2 of 3 Old 02-02-2014, 08:13 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
It should be fine. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 02-02-2014, 04:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Nothing different would happen
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
