Off set rims - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-31-2014, 09:28 AM Thread Starter
Off set rims
I have a 97 F250 and im putting new rubber on it im going from 265 75 16 too 285 275 16 and i wanted to get new offset rims as well where is a good place to find offset rims? and any ideas about how much of a offset i need would be greatly appreciated
Swany89b is offline
post #2 of 9 Old 01-31-2014, 09:31 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
I'm running stock Alcoa's and 285 and only have rubbing at full tilt. I'm 2wd:
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 9 Old 01-31-2014, 09:42 AM Thread Starter
So basically i can just get a small offset and ill be golden
Swany89b is offline
post #4 of 9 Old 01-31-2014, 11:05 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i'm running 285s on the stock alcoas. no rubbing on a 350 suspension. if your truck is 4x4 you should be unless unless your springs are very sagged.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 9 Old 01-31-2014, 11:15 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
If anything on the 2wd it would be like 1/2". The rubbing is very minimal.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 9 Old 02-03-2014, 07:32 AM Thread Starter
mines a 4wheel drive so hopefully it be the same
Swany89b is offline
post #7 of 9 Old 02-03-2014, 09:20 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Actually it's probably worse. Leaf springs take more room than Coil springs but if Terry says your good than I'd believe him.
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 9 Old 02-03-2014, 09:33 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm going to steal your hood Matt
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 9 Old 02-03-2014, 09:35 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
$1 says you can't outrun my dogs.
That means I'll see you soon?
Matt
'97
-Stage II trans.
BigFuel is offline
