Intercooler Piping clearance - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-30-2014, 12:33 PM Thread Starter
SoCalPwrStrk's Avatar
I am in the middle of my intercooler install, and I have the hot and cold side pipes in but I want to know if there is anything I need to avoid touching? right now the cold side is tight against the coolant reservoir hose and the hot side is really close to the power steering line, will this cause a problem? the hot side pipe still has the insulation on it if that makes a difference. Thanks
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #2 of 5 Old 01-30-2014, 12:40 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
if its touching the hoses it can cause them to rub through either the pipe or the power steering hose.
if there no way to avoid it, wrap the power steering and the pipe where they touch, so that it wont wear through either
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 5 Old 01-30-2014, 12:47 PM Thread Starter
do you think a larger diameter rubber hose would work for wrapping it?
post #4 of 5 Old 01-30-2014, 07:27 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
yes, that will be fine
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 5 Old 01-30-2014, 07:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are you using stock SD pipes?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
