94 f350 brakes question - Ford Powerstroke Diesel Forum
Old 10-15-2008, 09:53 AM
Is there a pump or something that creates vacuum for these brakes?
I know how the master and booster work but is there something else?
Old 10-15-2008, 10:07 AM
duct tape & zip ties
I do believe that the OBS trucks booster worked off vacuum that would be supplied by a vacuum pump. But don't take my word for it.
Old 10-15-2008, 10:54 AM
you are right im mix and matching my trucks here. On my truck because the cummins motor doesnt have a vacuum pump, I added a bendix vacuum pump. If I want to get rid of it what would I have to do? Swap brake boosters with something else?
Old 10-15-2008, 12:39 PM
there is a vac, pump on the driver side under the a/c comp.
if the brakes fell like they grab and then let go and repeat then it is prob. the vac. pump. and if the pump is makes a weird noise then its bad. pull the vac. line to the brake booster and see if there is suction. post back if you have more ?s
Old 10-15-2008, 01:10 PM
Swap in the hydroboost brake system from an OBS Super-Duty (F450)
Here: www.obspowerstroke.com
Go on TDS, there was thread about 2-4 weeks old on this subject.
Billy T.
gnxtc2@aol.com
Old 10-15-2008, 03:03 PM
Billy T.
gnxtc2@aol.com
that is exactly what I was looking for!!!
thanks,
dezl
