zf 5spd bellhousing - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-27-2014, 03:53 PM Thread Starter
mudweiser's Avatar
zf 5spd bellhousing
is the trans from a 460 the same as one for a 7.3?
02 ex limited 7.3 mbrp 4in. exhaust. 6 speed swap. southbend clutch. f250 springs front and rear.
mudweiser is offline
post #2 of 7 Old 01-27-2014, 04:22 PM
erics diesel's Avatar
short answer no
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 7 Old 01-27-2014, 05:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What he said ^^^
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 01-27-2014, 05:41 PM
Quoted: 54 Post(s)
Neither one has a bellhousing.
madpogue is offline
post #5 of 7 Old 01-28-2014, 03:21 PM Thread Starter
mudweiser's Avatar
bellhousing bolt pattern is what i am asking about yes they have a bellhousing it is part of the tranny
post #6 of 7 Old 01-28-2014, 07:16 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Are the internals the same (strength) between gas and diesel zf5s?
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #7 of 7 Old 01-29-2014, 03:39 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
the top two bolts are either closer together or further apart on the gasser trans than the diesel. either way they will not fit. also the gasser trans will have a wide ratio gear set which sucks behind the diesel
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
