Death Wobble
Ok I have a serious problem with my 95 model and I need some very good advice. When I am driving down the road and hit some bumps or potholes my tires on the front end begin shaking back and forth violently. I think the shaking begins with the up and down movement of the tires. We have replaced tie rods, tie rod ends, and the tracking bar. What am I missing? This thing is very dangerous and I am the only one that will drive the truck, mainly for safety reasons. HELP PLEASE!!
There has been a couple threads on here about it lately. On a 95 check to make sure that all of the radius arm bushings are in good condition and tight. Also look at the frame and the cross member where the brackets are rivited. Make sure they are not moving around. JJ
believe it or not, my issues finally went away with the install of a dual steering stabilizer
Also, have you checked your ball joints? Jack the truck up and tug on the wheel and check for play in it. Let us know. Craig |
ball joints are new. I am headed to change the oil now and I will check over the things mentioned and reply back. Thanks!
Checked the cross member at it seemed to be nice and tight. I had a few nuts lose on the front end parts and tightened then up as much as I could. I am afraid that the tie rods and other arms have become lose and now have wollered out the holes. I am afraid I need to replace all the front end parts. The truck has roughly 300,000 miles so I guess a little TLC wouldn't hurt it.
