Dana 60 rebuild - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-25-2014, 10:58 PM Thread Starter
sethc24's Avatar
Dana 60 rebuild
I swapped in a dana 60 into my truck but never had the money at the time to rebuild it. What i am looking for is the proper method for tightening the outer bearing. Also the part #s for the seals and bearings etc. The 60 is out of a 1995 f-350.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #2 of 4 Old 01-25-2014, 11:28 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
The spindle bearing?
Trucks and parts............
kanuck15 is offline
post #3 of 4 Old 01-26-2014, 11:18 AM
m j
wheel bearings i bet.
http://www2.dana.com/pdf/5309-3.pdf
page 15 in that manual direct from DANA/Spicer
you tighten them down good and tight to seat the bearing, this pushes any grease out of the way and ensures you have them fully on.
then you back it off. and tighten back until you have .001 - .010" total end play.
that is a free play approaching none.
basically you tighten it until you just cannot feel any movement in and out.
iirc bearing that run in oil get a little preload and ones that run in grease get freeplay
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #4 of 4 Old 01-26-2014, 08:21 PM Thread Starter
sethc24's Avatar
Awesome thank you very much mj.
sethc24 is offline
