Factory Trailer Wiring???
i have a 96 PSD F-250 and wanted to no did these some times come with a factory wiring harness for trailer hook up my truck has what looks like to be factory but I don’t no
Thanks Watson |
i dont know about the factory harness but i DO know there are fuses for the trailer brake/turn signals. one 10A for each side.
Some did come with a factory wiring harness.The plug will either be gray or dk brown.Some are located under the hood on the firewall by the brake booster,while others are located at the bottom of the dash,right above the center trans hump,Kinda were your right leg would be while driving.Wiring for the plug should have a blue=trailer brake feed wire,blk=power supply hot,white=ground,red=brake signal input from brake pedal cold side,,cold side meaning..on those trucks if you splice in the wiring in some of the other locations it will pick up your turn signal feed and cause issues with your trailer brakes.lastly ,if your truck is so wired,it may have a brwn wire,this should be your illumination wire for brake controls with back-ground lighting.Hope this helps.This wiring I have explained is for the brake control only..the wires for the trailer themselves should be located under the bed in the frame-rail.sometimes taped up.
my 97 has the factory 7 pin harness at the bumper and the brake controller harness plug under the center of the dash.
Thanks for the pm jbeasts10 as far as looking under the hood and stuff i have not make it that far it looks like I have a 7 RV plug in the back I am going to have to take a pic of this. I am not getting any power to that plug (or I couldn’t get the test light to work) for say but the guy that owned the truck seem to tap in to it or something and ended up with a mess of wires put I have power to the 7 point plug on the bumper. Some times my light work on the trailer some times they don’t. I am leaning toward a ground issue.
If any of this made since then you’re doing better than me. Put thanks for the input guys
heres my wireing
those 2 plug you posted look like the ones at the back of the truck that run into the rv plug
as far as the ones under the dash i dont think i have seen those put then agian i didnt no what i was looking for cool thanks for the pics EDIT: Found the plugs under the rear of the truck i have an extra plug also back there I will get pics as soon as my camera gets back home. Also i have the plugs under the dash. So do i have to call Ford to get a factory back control that plugs into those plugs under the dash or what?? Thanks for all the help Last edited by ComancheThis; 10-13-2008 at 06:06 AM. |
The plugs under the dash you have pictured one is for programing door looks, one is for the Ford AIC unit.
hey all, i was getting ready wire up my break controller yesterday and never really got to it. I was assuming a truck as old as 95 wouldnt have the plugs perintalled. the last pic Jarrod posted is exactily where my plugs are located. they are gray, but one has more pins. looks like they will fit my controller plug exactily. from what i can tell there are 5 pins total i think, 6 pin connector. i was going to post a similar question this morning. so this will be suitable for a controller? it has a 5th wheel ball and holes in the lower dash, so i know its had a controller before. is this correct?
is the three prong plug on the opposite side for the AIC? |
my back wiring has 7 pins 4+3. ford wants 120 for the bumper harness from the plugs. |
