performance - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-11-2008, 01:59 PM Thread Starter
z250kid's Avatar
performance
i have a 1996 f350
can i turn the fuel pump up?
is the wastegate adjustable
any negative sideaffects?
z250kid is offline
post #2 of 9 Old 10-11-2008, 03:23 PM
Welcome
theres no fuel pump to turn up, theres no wastegate. You can shim the fuel pressure regulator. Google Steve Baz and read his page, great info there
Good luck
Dan
341997 F250xcab lb FFD 230cc acodes H2E RockinSPerf. BDP elec fuel Tuned by Wildman tymar intake 3 1/2 SD dp 4" dual exhaust 17*hpop Bullydog electroluminscent gauges, pre and post pyro, boost, tranny, fuel pressure TC lockup and LED indicator light SD Intercooler +more 362 hp 725 tq 15.093@88mph(on stage 1s/stock turbo)
wk trk 03 SD
family rig 02 exc, edge evoII, mbrp 4inch, tymar
Big_Dan97 is offline
post #3 of 9 Old 10-11-2008, 09:28 PM
Welcome to the ORG. These trucks can be made to run real well. First step is the Air filter. I would do a DIY BHAF. Next would be a turbo back free flowing exhaust. Then you will be ready for gauges and a chip. I would recommend a Tony Wildman chip for the OBS trucks. JJ
04 F-550 CC 6.0 4x4 cab n chassis 4.88 XLT 193K
Money maker with utility bed.
97 F-350 CC 7.3 ZF-5 4x4 4.10 324K
Moves my stuff around.
Hardline is offline
post #4 of 9 Old 10-11-2008, 09:52 PM
Shaking the Bush Boss
CHUCK's Avatar
Another OBS!!! Bout time.
No on the fuel pump as stated b4. Shim the FPR, unplug the Exhaust Back Pressure Valve ( plug is located under and to the drivers side front of the turbo ) Exhaust ( 3" DP ) out to 4" or 5". DIT intake. Definatly gauges ( pyro, boost, trans temp ). IDM mod.
She'll run pretty good. Then you can start spending $$$ on her. Check my signature.
Welcome to the org.
Chuck
CHUCK is offline
post #5 of 9 Old 10-12-2008, 03:08 AM Thread Starter
z250kid's Avatar
because i head thee was a adjustable screw to tun the injection pump up?
z250kid is offline
post #6 of 9 Old 10-12-2008, 04:51 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
There is no screw to turn up on a powerstroke. Thats on old IDI trucks. The FPR shim mod will help some. But gauges and a chip are the way to go. These trucks are computer controlled
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 9 Old 10-12-2008, 08:01 AM
Yup the old IDI had an inspection cover on the side of the pump. You put it on TDC removed cover and turn up the fuel with an allen wrench. You could make them old trucks smoke as much as you wanted to. I did it to my 93 when I put the Banks Sidewinder turbo kit on it. That truck ran really good. So I decided to also do it to my work truck without the turbo installation and received no seat of the pants horsepower gains. JJ
Hardline is offline
post #8 of 9 Old 10-14-2008, 01:47 PM
Koonswala's Avatar
our trucks have all electronic fuel systems just a shim and new squerters bout the only way to got more fuel
94.5 powerstroke
3in dp 4.5 out
cat and muffler del
injetors
intake
guages
Koonswala is offline
post #9 of 9 Old 10-14-2008, 01:53 PM
broncrider's Avatar
finally another OBS family member
and welcome to the wonderful family of the .ORG
get a intake and exaust first. then gauges then a custom tuned chip.....anything custom is better then a tune in a can...hahahaha..
1996 F-250 dually convertion
intercooler
D.I.Y intake system
FPR shimmed
DIY exaust brake
dFuser 18k+
custom tunes by brians truck shop
3 inch down pipe/4 inch straigh pipe/6 inch
bullhaulers
SouthBend 350 Clutch
broncrider is offline
