dana 60 swap gear ratio - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-22-2014, 01:08 PM Thread Starter
I have a 1996 f250 psd 4x4. I have an opportunity to picck up a complete dana 60 out of a 1990 f350 with a 3.54 ratio. My rear axle is a 3.55. The question is, do i need to change the 60's gears to match or is .01 gonna be a big deal. Thanks
dieselup89 is offline
post #2 of 9 Old 01-22-2014, 01:10 PM
erics diesel's Avatar
It will work. It's eventually the same
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 9 Old 01-22-2014, 01:42 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
Dana didn't make a 3.55 so all 4x4 trucks with a 3.55 rear have 3.54 front
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 9 Old 01-22-2014, 01:47 PM Thread Starter
Ok, thanks. Next question, the stock shock mounts for my truck will work for the 60 right?
post #5 of 9 Old 01-22-2014, 04:03 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The noun that is bolted to the frame? YES
The mount that bolts to the axle? Drives side bump-stop tab MAY need to be trimmed
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #6 of 9 Old 01-22-2014, 05:02 PM
dr.deere's Avatar
Quoted: 19 Post(s)
The real reason a front axle is different by a small amount is because you need the front to pull just a touch to make it work right if the were identical the 4wd wouldn't function correctly.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #7 of 9 Old 01-22-2014, 07:56 PM Thread Starter
Thats what i needed to know. Thanks for the help
post #8 of 9 Old 01-22-2014, 08:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Actually if the front is 3.54 and the rear is 3.55 it's pushing more with the rear then the front is, however it being marginal it is still pushing more then pulling
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 9 Old 01-22-2014, 09:28 PM
Quoted: 50 Post(s)
A LOWER diff ratio turns the tire FASTER. (Example: two trucks, same tranny, top gear, same RPM, the 3.55 truck is going down the road faster than the 4.10 truck.) So yeah, the front will be turning about 0.28% faster than the rear. I always thought it was just a random result of Dana's choice of ring and pinion gear teeth vs. Sterling's; didn't realize it was for a specific purpose. This, of course, also illustrates why you should NOT proceed down the road on dry pavement in 4x4 for very long.
madpogue is offline
