What to do while the Turbos coming off? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-22-2014, 11:50 AM Thread Starter
I am taking the Turbo off to replace the seals on the fuel line fittings on the back of the heads. What would be good to replace while I have the Turbo off?
96 F350~CC~SRW~LB~4X4~Auto W/4.10's~107k orig. miles. 235/85-16 Tires
~TW tunes~Cass FF stage 1's~3"DP~4" Magnaflow~ AFE intake~Isspro guages~BD Exhaust Brake~Bilsteins~Banks IC~ T500~ D66~
Irate E Fuel and SS Up-Pipes~JW Trans~Aeroforce Scan Gauge-Tru-Cool 4739 Trans Cooler
Cupins is offline
post #2 of 5 Old 01-22-2014, 12:09 PM
You could add the Banjo bolt washers to the list!
Baileysbees is offline
post #3 of 5 Old 01-22-2014, 12:30 PM Thread Starter
Thanks, I will add those and the blue fuel lines.
Cupins is offline
post #4 of 5 Old 01-22-2014, 01:01 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Like I said over on PSN, check you up pipes for leaks
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 5 Old 01-22-2014, 01:06 PM
If your going to replace the fuel lines might as well rebuild the whole fuel bowl while you have it out!!
Sent from AutoGuide.com App
1994 F-350 4x4 Cab&Chassis DRW, Intake, CCV mod EBPV delete
