Slight miss at 1/8th to 1/4 throttle. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 01-22-2014, 06:55 AM Thread Starter
cthom388's Avatar
My truck has started getting this stumble or slight miss when i am cruising down the road at light throttle. It does not matter what gear it is in as long as im only at most at 1/4 throttle. When it does it its like the engine cuts out really quickly.I unplugged the ipc to see if it would help it did not.It will also intermitently run rough when i try to accelerate quickly its like the whole truck is shakey it also has a lopey idle sometimes. I also noticed when it goes back down to a idle it will have this weird fluctuation before it does. Could this be a ipr issue?
1995 F250 4X4 Zf5
  • TS 6 POS Power-Struck Tunes
  • 3" Silverline Dp to Straight Pipe
  • Custom E-Fuel/Regulated Return
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #2 of 27 Old 01-22-2014, 09:06 AM
Quoted: 43 Post(s)
Sounds like possibly the pedal. Maybe it's tripping the idle switch when you're actually a little off idle. Or maybe a bad spot in the position sensor.
madpogue is offline
post #3 of 27 Old 01-22-2014, 09:54 AM Thread Starter
cthom388's Avatar
Is there a way to check it?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #4 of 27 Old 01-22-2014, 11:09 AM Thread Starter
cthom388's Avatar
I checked it with a snap on solus and the volts to it slowly went up it never hit a bad spot and it maxed at 4.21 volts. I drove it and watched my number in a hard acceleration my ipr% was 36 and my icp pressure was at 2650. At a idle my ipr% was 12 and icp psi was 580.Then i ran a buzz test just because. They all passed but when i ran my cyl contribution test every cylinder failed!? This has got me scared any ideas?
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #5 of 27 Old 01-22-2014, 03:26 PM
Quoted: 43 Post(s)
Did you get actual codes (Pxxxx) with the CCT?
madpogue is offline
post #6 of 27 Old 01-23-2014, 11:11 AM Thread Starter
cthom388's Avatar
ran another cct test at lunch today heres what i came up with
-P0263-Cylinder 1 contribution/balance fault
-P0269-Cylinder 3 contribution/balance fault
These are the only cylinders that failed today. Yesterday it was all of them this makes no sense to me.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #7 of 27 Old 01-23-2014, 02:24 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
1 and 3 are on the same UVCH connector. I'd start looking there.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
The Following User Says Thank You to BigFuel For This Useful Post:
Micko (01-23-2014)
post #8 of 27 Old 01-24-2014, 06:39 AM Thread Starter
cthom388's Avatar
I already did all in good shape but i had a break through this morning i think. When i was shifting it bucked like crazy like it lost power and it threw alight that came on and off quickly. When i got to work i hooked it up to the scan tool and it threw a p0122 soft code.
P0122 Code - Throttle Position Sensor/Switch A Circuit Low Input.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
post #9 of 27 Old 01-24-2014, 09:05 AM
A scan tool usually won't pick up a glitch in a TPS circuit unless it is really bad, you need to use a lab scope to accurately test the circuit. But if you are getting a P0122 it would be a good bet your TPS is bad.
SlimMech is offline
The Following User Says Thank You to SlimMech For This Useful Post:
cthom388 (01-24-2014)
post #10 of 27 Old 01-24-2014, 09:55 AM Thread Starter
cthom388's Avatar
I have picked one up from napa im gona throw it on and let you know what happens.
1995 F250 4X4 Zf5
  • 6637 Intake
  • Stage 2 180/100's
cthom388 is offline
