stubborn mileage - Ford Powerstroke Diesel Forum
post #1 of 45 Old 01-20-2014, 08:33 PM Thread Starter
sethc24's Avatar
stubborn mileage
Hey guys i got a 1997 F-250 4x4, auto 226,000 miles extended cab longed. 4.10 Ls gears. 285/75/16 bfg ats.
Mods are: electric fuel conversion, dana 60, 6637, do-tuner, 3" down pipe, no cat, gauges, plenum intake boots and inserts from strictly diesel. New torque converter and flex plate, ww2, gutted pedestal and outlet.
No matter if i drive like a grandpa or hotrod it i cannot get more than 190 miles from the front tank. Out of both tanks i cannot break 400 miles.
1. None of my brake callipers are dragging.
2. I checked my up-pipes and they are not leaking.
3. I looked over all my fittings and e-fuel plumbing and i have no leaks.
4. My ebpv is unplugged because i gutted the pedestal and outlet.
Anything else i should be looking at? Im sure this topic has come up a heck of a lot but its just very frustrating.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #2 of 45 Old 01-20-2014, 08:43 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
seems odd , when towing about 5K i can get about 180 miles on the front , so something is up with yours , you sure you don't have any leaks any where? how many gallons does it take to fill up the front tank?
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #3 of 45 Old 01-20-2014, 09:57 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Only way I break 400 on both tanks is driving 60 mph. Either one of my trucks is that way. Seems like crap but I also don't have any leaks and both pickups have all new brakes no dragging. Can't wait to see other replies
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 45 Old 01-21-2014, 06:25 AM
I know my truck is a 2wd 5 speed manual, so a bit different thank a 4wd auto. But I can get 300 miles out of my front tank by itself. My front tank is the only one working as of now, and I'm very meticulous in calculating my fuel consumption. Being able to control my shift points, I've come to learn around 1600-1750 shift points is getting me the most routine 20-21mpg.
I know this doesn't help much, just showing it is obtainable. On a side note, hopefully when I get my rear tank working I'll be getting 550-600 miles between fill ups.
Jeremy
darkstardevil26 is offline
post #5 of 45 Old 01-21-2014, 11:20 AM
BR'sCrewCab's Avatar
If I am driving in town, or towing, I cannot break to 200 mark. But if I am on the freeway, and mindful of RPM's, I can usually hit around 240 miles on one of the tanks. There are so many variables that can affect mileage. Good Luck!
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #6 of 45 Old 01-21-2014, 12:43 PM
I have a 2004 f350 6.0 If I drive like a granny I'll get 600 miles to the tank if I drive like I stole it I'll get 530 520 maybe
Anigrelli132 is offline
post #7 of 45 Old 01-21-2014, 01:40 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
christ that's awful. I can get over 400 on either tank. combined i get around 800 on both tanks (on summer fuel, unloaded, on the highway) average 21-22. get around 17 city.
check for fuel leaks, boost/exhaust leaks, correct tire pressure. drive slow, accelerate slow. on winter fuel most people lose 2-3 MPG
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 45 Old 01-21-2014, 02:55 PM
700xxmaniac's Avatar
you have 33's are u make up for the 10% difference.. 210 is what your actually getting. how many gallons is the front tank... super-duty guy here
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #9 of 45 Old 01-21-2014, 03:07 PM
nine6stroker's Avatar
Quoted: 35 Post(s)
I get about the exact same mileage out of mine, whether I'm babying it or runnin the piss out of her. I normally average 160-180 out of either of my tanks running around town. Although this weekend I somehow got 215 out of my rear tank.
The most I ever got was 250 miles out of my front tank, 240 miles of that was running down the highway with the cruise set at 63 mph.
1996 F250 7.3 PSD 4x4 - "Dally"
281k miles
BDP stage 1's, T500 HPOP, TS6 chip, KC38r turbo, stock trans and fuel
Sitting on 2006 F-350 axles and suspension
nine6stroker is offline
post #10 of 45 Old 01-21-2014, 03:09 PM
Correction....usually 220.. a few times I have hit 240
