E40D temps... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-20-2014, 05:10 PM Thread Starter
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
E40D temps...
whats the normal operating temp for the E40D , and how long does it usually take to get to operating temp? , its about 60* out right now and was driving around town and temp never went over 140 but would also drop a hair then go back up , its a EV2 gauge , thought something was wrong going down the road cause the marker would somewhat flicker a hair but while it wwas rising through the temps , this normal?
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #2 of 5 Old 01-20-2014, 06:19 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
When I was in so cal I usually read between 160-200, normal at 180*
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 01-23-2014, 04:25 AM
Quoted: 3 Post(s)
Ambient air temperature and load on the transmission make a difference. AT 60F ambient with light load on the transmission, a reading of 140F sounds reasonable to me.
One could expect that as the ambient temperature and load on the transmission rise, so do the transmission temperatures. I've seen 220F or a bit above while towing a trailer in hot weather. If it ever got much higher than that, I would install a larger transmission oil cooler.
As to why the gauge might flicker while rising is anybody's guess. It's possibly just the way the gauge behaves by design as it moves through its function. Or it could indicate a fault of one sort or another.
Airstreamer67 is offline
post #4 of 5 Old 01-23-2014, 04:00 PM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
With ambient air temp at 60*, 140* trans temp is normal. That is about what I see on my 4R100 as well.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 5 Old 01-25-2014, 05:02 PM
bucwheat's Avatar
Mine reads 140 when not towing.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
