Fuel leak help
I have a constant dripping fuel leak from the right side of the fuel bowl at idel. It is coming out of the weird looking bolt-like object that is screwed itno the filter housing and has a wire hooked up to it at it's end. What is this called and do I need to replace it?
Thanks alot! Mark |
My Problem area looks like its some fuel pressure sending switch but I have no clue what to do? Replace it? Tighten? or What?
Can you narrow it down from this link what could be leaking? Powerstrokeshop.com
Thanks for the diagram... I tightened it up and soo far its not leaking. Its the Vaccum Switch... if it starts to leak again what should I do???
You need to repleace it or put a 1/8 NPT plug there, dont overtighten.
