'99 F-550 Gearing question - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-19-2014, 08:39 PM Thread Starter
Ok, I took an F-550 that was used by AGWAY as a sprayer unit. It had a 500+ gallon tank and spray booms mounted on the back. It also had 11-22.5 rims and tires mounted on it.
7.3 Diesel 4x4, 6-speed, 4.88 gears.
Turned the truck into a Hot Shot truck. With the proper size tires, it now is geared way to low. It runs 65mph at 2500rpm in 6th (OD) gear. What gear set should I go with to actually be able to run at highway speeds without scattering the motor??
Thanks
Marc M
Marc M is offline
post #2 of 19 Old 01-19-2014, 08:51 PM
luke7.3's Avatar
Quoted: 24 Post(s)
4:10 all the way
By the way, nice conversion! That truck looks great compared to before
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #3 of 19 Old 01-19-2014, 08:57 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
IIRC 4.88 and 5.13s were the only 2 gear choices for the Dana 130 rear axle in the F550. That is 1/2 the reason for the 18k gvw
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 19 Old 01-19-2014, 09:02 PM
luke7.3's Avatar
Quoted: 24 Post(s)
He needs to do a Dana 80 axle swap then switch to 4:10 is what I mean. You can get one from an F350 at a junkyard.
Luke
luke7.3 is offline
post #5 of 19 Old 01-20-2014, 01:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Honestly a GV unit or similar would be better being as a Dana 80 rear would decrease the gcvwr as well as the gvwr, why would you want a smaller load rating by going down in axle size?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 19 Old 01-20-2014, 05:14 AM
Quoted: 4 Post(s)
Why would he want to put a Dana 80 in place of the Dana 130? Talk about going backwards
post #7 of 19 Old 01-20-2014, 02:14 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Wasn't sure if you could put 4:10s in a 130 and I know you can in an 80. He wants to run at lower RPMs and the only way to do that is to raise the ratio.
Luke
luke7.3 is offline
post #8 of 19 Old 01-20-2014, 07:23 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Or add a gear vendor , or taller tires, there are a few things, but I wouldn't want to sacrifice gross weight load for a better hwy gear
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 19 Old 01-20-2014, 07:33 PM
luke7.3's Avatar
Quoted: 24 Post(s)
It really just depends on what he wants to use the truck for. Right now the truck probably gets 6-8 mpg and the engine is winding that high of RPMs, which is not good and definitely a killer on your motor going highway speeds. If he plans on using the truck as a DD or a medium weight tower (around 10,000 lbs), then he needs higher gears. 4:10s are what most 350s use-IDK if 550s ever had them or not, and I think they would match his criteria. But I have no f'ing clue how to do a gear swap or if he needs a different axle.
Luke
luke7.3 is offline
post #10 of 19 Old 01-20-2014, 07:38 PM
ZWilson07's Avatar
Does the legal portion of the truck change if the axle is switched out?
I know a lot of states are far different then other ones when it comes to towing laws. Some its only what the factory said for that year and nothing else, others as long as you got the money you can have whatever you want within reason and your vehicle class.
So I guess if his state only goes by what the door tag says, does it matter if the axle is swapped? To me if they were so strict that it has to have that exact axle and they would check that, then simply changing the gear ratio from the factory one would be enough to make it illegal as well.
I guess just depends on how strict the state is?
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
