Will a 7.3 run on Kerosene? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-19-2014, 08:21 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Not sure how but a friends wife filled one of the tanks on there 7.3 with Kerosene. It should be able to burn that correct?
I suggested that he treat it with winterizer but is there anything else needed?
Or is he screwed?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 11 Old 01-19-2014, 08:34 AM
Should run on it just fine. That's what #1 Diesel is anyway. I wouldn't treat it with winterizer, I don't believe. Kerosene is thinner than #2 diesel, and has a lower gelling point, so you should be alright. Only issue I can think of is that most of the kerosene here is dyed red, so he may have an issue if he gets pulled, the same as he would to get caught running off road diesel.
sgg93 is offline
post #3 of 11 Old 01-19-2014, 08:42 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Right on thanks for the response. Ill pass it along.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 11 Old 01-19-2014, 09:00 AM
Gene's Avatar
Quoted: 3 Post(s)
Good Morning. Check out this link I found. Should burn it OK, lower power/worse mileage. Might also clog the fuel filter due to cleaning everything out. Kerosene is a stronger cleaner than #2 diesel.
The difference beween Diesel Fuel and kerosene
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #5 of 11 Old 01-19-2014, 09:02 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Add some 2 stroke due to less lubricity as well. Mileage will be cut about in half
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 11 Old 01-19-2014, 09:03 AM
Quoted: 5 Post(s)
running on kerosene is ok, just doesn't have the same mileage or btu output as diesel. I run a mix in the winter kerosene/diesel on the cold days to keep from gelling. I also run on waste oil and anything I can get my hands on, but thats another story. I also think long term use may be bad if used straight, just for lubricity purposes. JMHO
mastertech79 is online now
post #7 of 11 Old 01-19-2014, 10:19 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
So would it be a good idea to run kerosene every now and then to clean out the fuel system? Glad this was brought up, learning more and more from this forum
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #8 of 11 Old 01-19-2014, 10:54 AM
Quoted: 5 Post(s)
I don't think its a bad idea, I have noticed through the years it helps to clean stuff out, not going to hurt at all. I have been running this in my truck for 5 years now and had the injectors out before with no ill effects.
post #9 of 11 Old 01-19-2014, 02:00 PM
Quoted: 53 Post(s)
The kerosene I see on the shelves of the hardware, that my Amish friends use in their lamps, isn't dyed red.
madpogue is offline
post #10 of 11 Old 01-19-2014, 05:40 PM
seems unlikely to me that the tanks of the truck got filled from gallon cans. I figure it's more likely that it was out of the pumps at the filling station.
sgg93 is offline
