Driveline Vibration? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-18-2014, 11:16 AM Thread Starter
PSD_rookie's Avatar
Garage
Ok so I've recently had a vibration develop and I am trying to narrow it down, the vibration starts at 40mph and becomes quite noticeable at just above 50mph then settles down some at 60mph. I've got an ext cab long bed, and I have just had a custom 1 piece driveshaft made because I thought it was that, plus my carrier bearing and front u-joint were pretty shot. I have heard about the ICP or bad injectors possibly being the issue, but it is not rpm dependent, I've dropped down to 4th gear and have the vibration still.
I need help ASAP because its my daily and riding my motorcycle in the 20s and 30s is no good.
TOTALED - 95 F250 XLT ECLB 4x4
4" turbo back, DIY tymar, Boost/EGT/Trans temp Gauges, 35/12.5 tires, ZF-5 swap with solid driveshaft, Oh yea, and P-pumped 12 valve swap
97 F350 CCLB 4x4
PSD_rookie is offline
post #2 of 5 Old 01-21-2014, 11:16 AM
BR'sCrewCab's Avatar
Have you tried adjusting the carrier bearing bracket?
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #3 of 5 Old 01-21-2014, 03:37 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
^^^ he's running a one piece drive shaft now. What do your pinion and t case angles look like? Do they match? Are u running any lift? Angles on your one piece shaft?
Have u done a D-60 swap? Checked out your front end for sloppyness. Have u balanced your tires or rotate them to see if the vibration changes or moves?
Sorry for all the questions but just need to know more
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 5 Old 01-23-2014, 04:35 AM Thread Starter
PSD_rookie's Avatar
Garage
The transfer case/axle angles are maybe off by a degree or 2 at most, they're not visibly different, I have done the Dana 60 swap up front and swapped to f350 blocks in the rear along with that. I have eliminated the front end as the problem by taking the rear of the truck off the ground and reaching the same speed and getting the vibration. I pulled the wheels off and still there, pulled the drums to make sure they weren't warped bad or cracked...still there.
Thanks for the replies
97 F350 CCLB 4x4
post #5 of 5 Old 04-15-2014, 06:17 PM Thread Starter
PSD_rookie's Avatar
Garage
I know I'm bringing back an old thread but wanted to give input in case someone else comes across this. Ends up my 1 piece driveshaft was built 2" short so it wasn't fully in the slip joint....I had my transfer case rebuilt and replaced the axle(which I got a good deal on a C5 so I'm not too mad about that)
97 F350 CCLB 4x4
