Coolant Loss - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-18-2014, 11:48 AM Thread Starter
Coolant Loss
I've got a 94.5 PSD that's losing coolant. It lost almost two gallons over the past 3000 miles. I can sometimes smell coolant right when I turn the heater on, but it's been that way for a year or so. The coolant isn't in the oil (Oil is still clean and black), and I'm not finding any coolant leaks. The only other issue that I've seen is that when it's very cold (I noticed it the other day when it was about 5 below, and this morning when it was about ten) I can sometimes see a small amount of vapor from the tailpipe when I accelerate. Normal with a gas engine, but I thought it was strange in a diesel. Does anybody have any idea where the coolant might be going? I kind of considered blown head gasket, but that should mean combustion gasses in the coolant, right?
sgg93 is offline
post #2 of 5 Old 01-18-2014, 02:27 PM
erics diesel's Avatar
sounds like maybe and injector cup is bad
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 5 Old 01-18-2014, 02:46 PM Thread Starter
i wondered about that too after i thought some about it. I wonder if there would be any way to tell with a pressure tester. I was going to get one tomorrow and pump it up and see if i can find the leak. Pinch off the heater hoses and see if i can isolate that. The thing that got me is how much i lose.
sgg93 is offline
post #4 of 5 Old 01-18-2014, 05:07 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine does the same thing, pulled my injectors and one fills with coolant, you have a bad injector cup
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 01-18-2014, 10:38 PM Thread Starter
Well I guess that's better than a blown head gasket. I've done the injectors, but never messed with the cups. How bad are they to do? I know rosewood sells the tool...does anybody happen to have it that might loan it?
sgg93 is offline
