FUEL LEAK - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-18-2014, 08:50 AM Thread Starter
FUEL LEAK
I have a fuel leak at the hard line fittings going from the banjo bolt to the back of the heads. Do you need to remove the turbo to get to these?
Thanks..........
96 F350~CC~SRW~LB~4X4~Auto W/4.10's~107k orig. miles. 235/85-16 Tires
~TW tunes~Cass FF stage 1's~3"DP~4" Magnaflow~ AFE intake~Isspro guages~BD Exhaust Brake~Bilsteins~Banks IC~ T500~ D66~
Irate E Fuel and SS Up-Pipes~JW Trans~Aeroforce Scan Gauge-Tru-Cool 4739 Trans Cooler
Cupins is offline
post #2 of 3 Old 01-19-2014, 07:06 AM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
from the banjo bolt to the hard line? no
from the hard line to the back of the head? yes
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 3 Old 01-19-2014, 07:10 AM
troykimber's Avatar
you can get the banjo off but you will have to slightly modify a wrench to get in there nicely...
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
