block heater - Ford Powerstroke Diesel Forum
Old 10-04-2008, 05:46 AM
block heater
when do you guys start plugging your trucks in?
Old 10-04-2008, 05:52 AM
Conservative and Proud
I just watch what the temps will be over night and how much humidity we'll have (windshield ices up easily out here in Oregon).
You can also get yourself a time to plug into to have your heater start just a couple hours before you take off.
Old 10-04-2008, 05:57 AM
yeah true its about 50 here in jersey overnight little rough in the morning
Old 10-04-2008, 05:58 AM
Usually I only worry if it's going to be freezing overnight. So your truck is starting rough and it's only 50?? Sounds a little odd.
Old 10-04-2008, 06:05 AM
it was 45 this morning and it seemed like it didn't want to start, actualy loped for probably 10 seconds than ran fine
Old 10-04-2008, 09:43 AM
Mine never wants to start on the first try with a cold engine, whatever the outside temperature. It always take three tries, but it always runs smoothly after that.
I plug in the block heater, when it is going to be frosty, it always starts the first time when the block heater is used.
Dave
Old 10-04-2008, 10:01 AM
Send a message via AIM to ford_trck
I usually plug it in if it's going to be 32 or lower
Old 10-04-2008, 10:10 AM
Powered by Deez Nuts
40 or under. unless glow plugs arnt workin, 80 down.
Old 10-04-2008, 12:06 PM
im about 20 or lower. i only have to plug it in for about 3 months out of the year
Old 10-04-2008, 04:25 PM
I start at about 32 or below
