Weirdest trailer wiring issue ever. Need help badly - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-15-2014, 03:12 PM Thread Starter
HCSTROKER11's Avatar
Ok I have a 97 f350. The trailer is a 35 foot gooseneck. Used a power probe pro to figure out which wire is which. So I hooked them up Into a brand new 7 way trailer plug and hooked it to my truck and everything is jacked up. As soon as I turn the key my rear lights come on and also on the trailer. It's not the running lights or brake lights because they are too dim. My blinkers work. But as soon as I hit the brakes I lose lights on the trailer. This is where it gets wierd. To see if my wiring was wrong I hooked it up to my buddies 06 f150. Everything works perfect!! So then I say well it's my truck. I then go and hook the lights on a 18 foot car hauler. Guess what. Everything works perfect!! What's the deal. Need help badly.
1997 f350 4x4 off road.
353k miles
Stage 1 swamp injectors. TS chip. Leveled on 35" Federal tires and black 18 inch pro comp wheels
3" downpipe into 5" straight pipe 6" tip. (Diamond eye)
1987 Chevy 1ton lifted 24 inches on 53s. Duece and a half transfer case. Mud truck.
HCSTROKER11 is offline
post #2 of 16 Old 01-15-2014, 03:51 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The 18 foot car hauler a 7 pin plug? And are you using the same plug for both trailers?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 16 Old 01-15-2014, 03:59 PM Thread Starter
Yes both are 7 pin and using the same location.
353k miles
post #4 of 16 Old 01-15-2014, 04:30 PM
grounds
check your grounds. DC is funny with bad ground. Do not rely on ball metal contact.
Hope you figure it out...
WI F350 is offline
post #5 of 16 Old 01-15-2014, 04:36 PM Thread Starter
Ok I understand the whole grounds thing but why does it work on my buddies truck
353k miles
post #6 of 16 Old 01-15-2014, 04:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Both trailers have brakes?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 16 Old 01-15-2014, 05:08 PM Thread Starter
Yes both electric brakes
353k miles
post #8 of 16 Old 01-15-2014, 06:06 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's funny Kause were texting the exact same thing too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 16 Old 01-15-2014, 06:17 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Re wire it all. Start over and do it correctly because it's wrong.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 16 Old 01-15-2014, 07:34 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Swap your brake activation wire and your accessory wire on the truck end.
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
