2.5 PMF RSK Project - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 229 Old 01-15-2014, 02:20 PM Thread Starter
BR'sCrewCab's Avatar
2.5 PMF RSK Project
I am planning out my next project on the truck.
I haven't really liked the rake on it since I did the D60 swap, so I am now going to go through with the RSK. I believe that with V or U code Ford SD Springs and a 2.5 PMF RSK kit, I will be sitting much more level. I did notice a difference in ride moving to the F350 springs up front, but looking forward to the RSK ride that I read about with the RSK testimonials I am always reading.
Here is the list of things I know I need:
RSK Kit (going with the PMF kit)
New Shocks (Billstein 5120)
Front Springs (U or V Code)
New U-Bolts
I assume I will need a new track bar? or track bar drop bracket?
What about the rear, might as well round it out. What SD springs are needed for the rear, and are they a direct bolt in? At the time I did the D60 conversion, I did put in 350 blocks.
Thanks in advance for your help. Feel free to provide suggestions of things I may not have thought of and any experience you can add.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #2 of 229 Old 01-15-2014, 02:38 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The rears your looking for are B codes iirc, and pmf sells an adjustable trac bar for their kit as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 229 Old 01-15-2014, 03:57 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
V codes up front. U codes are even softer but john (97beast) is the only one I know of running them
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 229 Old 01-15-2014, 06:44 PM Thread Starter
Do you agree that I should be sitting level once I complete the install?
post #5 of 229 Old 01-15-2014, 07:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You would be level now if you would have left the stock 250 blocks in
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 229 Old 01-15-2014, 07:29 PM Thread Starter
That rear end squated quite a bit after the conversion which is why I threw the 350 blocks under it.
post #7 of 229 Old 01-17-2014, 01:13 PM Thread Starter
Anyone purchased their leaf springs from SDTruckSprings.com?
X Code Leaf Spring 1999-2004 Ford F250SD, F350SD 4wd - Leaf Spring (Front) [43-818] | $98.95
-OR-
1999-2004 Ford F250SD, F350SD 4wd - Leaf Spring (Front - 2 Leaves) - 43-812 | $119.95
post #8 of 229 Old 01-17-2014, 03:25 PM
ol_Blue97's Avatar
With the Pmf 2.25 kit and v or u codes and 350 blocks in the rear your will be level. Keep in mind a level truck doesn't tow well and will squat badly when u throw a bag of trash in the bed.
X codes will lift the front even higher and the. U will need bigger blocks in the rear
FRANK THE TANK
post #9 of 229 Old 01-17-2014, 05:36 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
When I first did my rsk (sky) I used V-codes, I thought one was a little saggy amd replaced with W-codes noticed no difference in ride quality or hight. W's are rated like 200lbs less than v's...
I have a 4.5" rsk and 2" aal upfront, stock 350 block and 2" lift springs in the rear and she sits level as can be.
Sent from AutoGuide.com App
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #10 of 229 Old 01-18-2014, 04:00 PM
I just did this last weekend on my 95 f250. I did the PMF 2.5 with v codes and swapped the rears with b code springs. I have been driving it with no track bar so far and its been fine. Im going to lengthen it about 1/2" then put it back on. I did a 4" block in the rear and it had to much of a rake for me so i put in a 3" block instead. Tires are 315/75/16 with no rubbing.
boggin79ford is offline
