Oil pressure gauge - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-13-2014, 08:32 AM Thread Starter
Oil pressure gauge
Was wanting to put in an aftermarket oil pressure gauge, was wondering with the hpop, if I had to have ant special gauge for higher pressure numbers
austinlibke is offline
post #2 of 15 Old 01-13-2014, 09:09 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
For regular pressure all you'd need is a 100 psi sender and it can be mounted to the right of the oil filter for bottom end pressure or "T'd" into the sender on top of the HPOP sump to see HPOP supply pressure. If HPOP pressures are what you are after ISSPRO and I believe AutoMeter both make a 3500 psi sender and gauge for the high pressure rail.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 15 Old 01-13-2014, 10:31 AM Thread Starter
I've seen the hpop gauges, and that was why I was curious.
When you say right of the oil filter, you mean there is a fitting there I can thread my gauge into?
Its been awhile sense i've looked under there
post #4 of 15 Old 01-13-2014, 10:45 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 15 Old 01-13-2014, 03:35 PM Thread Starter
Ah!! Okay. Thank you!
post #6 of 15 Old 01-19-2014, 02:54 PM Thread Starter
Quick followup.. What kind of pressure readings should I be seeing? at idle and with throttle
post #7 of 15 Old 01-19-2014, 03:01 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Spec is 10-40 psi at idle and generally there is no off-idle spec. Al long as the pressure goes up with off idle rpm it's fine.
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 15 Old 01-19-2014, 03:08 PM Thread Starter
Okay, I put the gauge in and at idle it reads just under 10, presuming the difference is coming from the gauge I have, $25 from O'Reilly to keep me going till I get Autometers
post #9 of 15 Old 01-19-2014, 03:23 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Below 10 psi may indicate that it's time for a LPOP....
Matt
'97
-Stage II trans.
BigFuel is offline
post #10 of 15 Old 01-21-2014, 08:06 AM Thread Starter
I've heard of other possible low pressure culprits, any way to confirm the lpop without replacing it?
