96 7.3 should i rebuild injectors or buy stage one.
Is there that much difference.
huge difference, from 90cc to 160cc. the superduties only put out 140cc's so stage ones for an obs is a big step up
If i drive it the same with a light foot will i see the same mpg or better?
def go with stage 1's
you will need a custom tuned chip for the stage 1's.... and you will prob see better MPG after the tuning... dont forget your gauges, intake, and exhaust -Raul |
Definitely do the stage 1s I just pulled out my stock injectors yesterday and sent them off to be rebuilt to stage 1s 90cc to 160cc is a huge difference and from what I hear its like driving a completely different truck. Def go with a TW chip as well stage 1s will act like stock without a chip and with a TW chip you will see the full potential.
Im doing it through Jim Rose at DIY injectors for 475 bucks, sending him the stock ones saves me a core charge and its cheaper than getting remanned ones, removal was pretty easy
so how many horse are those injectors and do you have the stock turbo and do you need to update the turbo for those
Stage 1s flow 160cc and give gains up to 140hp a bigger turbo is not neccesary but if you want to see the full gain of the injectors you will want one. With a custom tuned chip and these injectors you should see a gain of 110hp
Or is it $475/ea? heh If it's /ea then that's a rip off! ![]()
