Wanna talk about frame rot? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 Old 01-10-2014, 10:24 AM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
Me either but unfortunately it's a problem up here.
My spring hangers are trashed. They will be replaced when the weather is warmer (feel free to send me quotes. rear: front and back).
However, it's quite concerning to see that the frame appears to be rotting through in the same area as the rear front hanger on the driver's side (read the previous again and visualize...... got it? good!). The rest of the frame is fine. I fear that when i remove the hanger i won't have much frame left when i'm done
What options are out there to fix this or is it terminal and i should just enjoy what little life she has left?
Thanks,
Eric
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
post #2 of 23 Old 01-10-2014, 03:58 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
drop the front tank move the fuel lines out of the way. remove spring and hanger, weld a plate across the hole reinstall with a new hanger (you will need longer bolts if you cover the holes with the plate)
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 23 Old 01-11-2014, 05:23 AM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
Thanks.
No holes in the frame yet. Just layers of steel pealing away.
Cut the area out and weld a plate in?
-Eric-
218,000
EflumE is offline
post #4 of 23 Old 01-11-2014, 01:20 PM
the baconator
Quoted: 143 Post(s)
i wouldn't cut it out just clean it up and weld a larger plate to the inside/outside of the frame maybe both inside and out, depends on what you want to do there
post #5 of 23 Old 01-11-2014, 02:01 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Personally I would cut it out and POSSIBLY plate
here is a frame that I cut out for the shock brackets and welded in new, I actually use the Exact section of good frame, I didn't drill one hole.
Does your frame look like this behind the hanger?
mikenj likes this.
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #6 of 23 Old 01-11-2014, 05:30 PM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
Thanks Terry, my initial thought was to clean it up and put plates on each side.
I have to be honest, when I posted this I was hoping you would weigh in Brad because I've seen how far you've been in to these trucks, and you didn't disappoint. Thanks for the pictures, they help a ton. I don't think The frame is anywhere close to the last picture you posted but I won't really know until I can get in there and clean stuff up. I'll try to get some pictures up. Now I Just need to find someone that can weld
Hmmm.... Rad support suggestions? Or am I pressing my luck?
-Eric-
218,000
EflumE is offline
post #7 of 23 Old 01-12-2014, 08:08 AM
Quoted: 4 Post(s)
Take a pick hammer and BEAT on and around the rusted area. You will not hurt anything, it will just expose what metal you have left. That frame rail in that last pick was not that bad UNTILL i used the air hammer to drive out the rivets exposing the bad metal
Rad supports are hard to come by and they bring a premium.
I just bought 2 from Florida on Friday
post #8 of 23 Old 01-12-2014, 09:51 AM
Quoted: 47 Post(s)
Eeek, how bad did it hurt for shipping?
madpogue is offline
post #9 of 23 Old 01-13-2014, 03:14 AM
ja9788's Avatar
I came across these last week. Whether or not they are LEGIT diesel supports and not the gasser ones, I'm not sure. You would have to call and verify but thought I'd at least pass it along.
F4TZ16138A Black New Radiator Support F250 Truck F350 Ford F 250 97 96 95 Car | eBay
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
post #10 of 23 Old 01-13-2014, 05:07 AM
Quoted: 4 Post(s)
If that picture is of what they are selling, they are NOT diesel
