Eaton Fuller - Ford Powerstroke Diesel Forum
Old 09-27-2008, 09:48 AM
Eaton Fuller
I want to slide an Eaton Fuller 10spd or 18 spd under my 95 powerstroke. Is it possible??? Dont ask why cause I dont even know. haha
Old 09-27-2008, 10:00 AM
now that would be sweet,grabbin 18 gears in a psd.goodluck
Old 09-27-2008, 10:10 AM
Im sure its possible just the probability. I have plans to turn my truck into a full air system. Air brakes Air Ride. ETC.
Old 09-27-2008, 10:15 AM
Eaton makes a 6 speed.
All are internationals at work have the dt466(the brand new ones have the maxforce equivalant. i think they changed the model number. not for sure tho.) \
Most of the older one's have the Eaton 6 speed and the newer one's have an Eaton 10 speed.
There all 2004's and newer.
So if they'll bolt to the dt466, you might be able to make it work. I dont know tho, as the dt466 is quite a bit bigger motor.
But of course, anything is possible with the right amount of money
Old 09-27-2008, 10:16 AM
Air brakes?????????????
Why??????
I drive trucks for a living and love everything about them,
but i still wouldn't try to do that to my pickup.
Old 09-27-2008, 10:29 AM
Send a message via AIM to ford_trck
I wouldn't mind converting my truck to air brakes. They are easy to change and work on but the shear size and weight of the drum, adding brake chambers, s-cams and having everything lined up and straight could brings up significant cost.
As far as the transmission. The shear size and weight of a 10 or 13 speed will be one thing. And then you will probably have to get an adaptor plate. The closest to a bolt up would be finding an International Harvester with the International engine and a 10 or 13 speed. Then you will need an air compressor to supply air to the trans for the high/low range. The width may prove to be a problem too so your exhaust might have to get dumped at your downpipe. But anything is possible. If you add a pto to the setup and make your bed a dump bed that would be pretty sweet too.
Old 09-27-2008, 04:22 PM
I drive truck for a living too and love everything about them. If I am going to spend money Im going to make my truck unique. So I wont settle for anything less than an 18 speed. Plus I think air ride would be cool and since I have air ride why not brakes
Old 09-27-2008, 11:23 PM
get a splitter, it gives u a high and a low side so if u have a 5 speed you'll have 10 gears , u just go through all 5 gears flip the switch u mount on the shifter and bang through 5 again
Old 09-27-2008, 11:24 PM
was thinkin about doing this with a common rail cummins swap for my '86 Bronco but now iam leanin more toward putting a Perkins or Kubota diesel in it
Old 09-28-2008, 01:44 PM
Here's your air seat, third one down:
Air Suspensions for Pickups & Medium Duty Trucks
and here's your air ride (my chassis guy's truck, he built everything himself):
jwracing-fab.com :: View topic - My 1997 F350 with 2 feet of lift
Billy T.
gnxtc2@aol.com
