DIY high idle mod anyone do it? pics?
Has anyone done the high idle mod? can you pick what rpm you want to idle at? anyone have any pics of their install? thinking about do it, I don't have the cash for a chip now, so this will give me my high idle for the winter time atleast
I just finished mine. North Texas Power Stroke Association - DIY AIC Mod
I ordered the pot and relays from digi key. and just picked up the switch from a local auto parts store. Make sure you can solder half way decent. Digi Key part numbers 2 relays Z785-ND 1 pot GU2021S26-ND And at the auto parts store, pick up some stake on connectors for the relays! Other than that, it is pretty easy and straight forward Good Luck |
You can also do it the el-cheapo way......get yourself a manual carb choke cable, screw a bracket behind the throttle pedal and you got yourself an AIC. Safe no but it works.
Billy T. gnxtc2@aol.com |
You attach the cable to the pedal and pull down the pedal.Billy T. gnxtc2@aol.com |
