Zf5 swap - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-09-2014, 05:18 AM Thread Starter
HOYBOY's Avatar
Zf5 swap
Okay I got this 96 Ford F 250 7.3 powerstroke with the e4od I also have a 94 f 250 7.3 powerstroke 5 speed looking to do a complete swap into the 96 bothe trucks are the same wheel base the questions I have are about the computer and a block off plate on the dash cluster the 94 no longer has a steering column so I have to get a new one from the junkyard, will the PCM out of the 94 work in the 96 otherwise I have everything to do the swap also interested if anybody would like me to do a full write-up on the swap. Will be planning on doing the swap in the spring/summer. Here are pics of the trucks red/white is 96 then the 94 green parts truck.
Sent from my DROID RAZR HD
ID:	223810   Click image for larger version
SLOW STROKIN
2006 6.0 Amarillo
95 Ford F250 4x4 7.3 blue Charlene (sold)
94.5 Ford F250 4x4 7.3 Green two-tone Tracy (junked)
HOYBOY is offline
post #2 of 5 Old 01-09-2014, 06:40 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
everything will swap right over (unless the 96 is a late 96 cali model). the block off plate is in the dash cluster the only part you need form the column is the cover
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 5 Old 01-09-2014, 06:58 AM Thread Starter
HOYBOY's Avatar
Glad to hear that anybody interested in a full on write-up?
SLOW STROKIN
2006 6.0 Amarillo
HOYBOY is offline
post #4 of 5 Old 01-09-2014, 07:34 AM
dr.deere's Avatar
Quoted: 19 Post(s)
You also don't need to swap pcms to auto to stick the other way and will
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #5 of 5 Old 01-09-2014, 07:32 PM
theforeman57's Avatar
Quoted: 4 Post(s)
I do not need to say it since it has already been said, but It is straight forward.
There are several full write ups on the web, one on FTE, I forget the other site, but none that I know of on here.
Some Punctuation would go a long way in helping everybody understand ya. I am not trying to be a grammar nazi, or be a d!ck
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
