Dana 60 stub axle question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-08-2014, 02:59 PM Thread Starter
Hello, I've been lurking on the site for a while and now I have a question. I'm in the process of swapping to a dana 60 on my 96 250. On my axle the outer stub shaft does not have a groove for the snap ring. All the pictures I've seen show a groove and a snap ring at the outer part of the splines at the lockout. I would assume the snap ring helps hold the shaft tight to the spindle for the seals to work better. Also the "slinger" that goes on the stub before the spindle seal, is it needed? If not is it recommended? I got my axle with no hubs and the spindles were trashed so I never saw how this one went together from the knuckle out. Any input would help, Thanks.
Edit/Delete Message
mzwizanski is offline
post #2 of 4 Old 01-09-2014, 09:11 AM
Quoted: 85 Post(s)
Feedback Score: 4 reviews
The outer snap ring is not necessary on the d60 like it is on the ttb50. The slinger is not needed but it does help keep trash out of the axle tubes. Make sure that the seal surface on the back side of the spindles is clean, smooth and lubricated with a light coat of grease before installing or your spindle seals won't last very long.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 4 Old 01-09-2014, 04:11 PM Thread Starter
Thanks that helps clear things up
1996 F-250 7.3 4x4 RCLB 221k
post #4 of 4 Old 01-10-2014, 04:56 AM
m j
ball joint d60?
the spindle seal is different then the older style. takes a different part number entirely
if you want to run older hubs you can make a snapring groove. I just swapped my hubs for 1978 vintage Spicer hubs as my hubs had excessive play in them.
I just made a groove with an angle grinder and cutoff disc
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
