Dip stick fix? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-08-2014, 01:01 PM Thread Starter
Dip stick fix?
I've got my motor pulled and on a stand.
I plan on addressing the common pan leak at the dip stick.
Has anybody ever tried welding a bead around the inner and outter flange with a mig welder?
clint_ives is offline
post #2 of 6 Old 01-08-2014, 01:07 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Never heard that. I used Strictly Diesel's in truck fix. Worked GREAT.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 01-08-2014, 01:24 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Dont do that. The adapter is aluminum. Tried it. Didnt go so well, If you could braze it you might have better luck considering the different metals.
Ive used both the strictly diesel dipstick fix and put a new adapter in. When I used the new adapter I ran a bead of right stuff gasket maker around the inside and out. That stuff is seriously tough
Trucks and parts............
kanuck15 is offline
post #4 of 6 Old 01-08-2014, 02:13 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Is the dipstick leak common only in the northern states?
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #5 of 6 Old 01-11-2014, 01:21 PM
Nope I'm in Texas and I have the leak but it's not terribly bad yet so I'm letting it go until it gets real bad then I'll buy strictly diesels part
96 7.3 powerstroke, 4.10 gears, 5 speed f350 single cab dually, 3in downpipe from turbo, cat delete and straight piped-SOLD
2001 dodge 2500 2wd auto
7.3kid is offline
post #6 of 6 Old 01-12-2014, 06:09 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
nope it's common all over the place. eventually the orings swell and pushs out o there grooves breaking the seal. then some idiot will come along and over tighten the adapter so that it is distorted and will never seal correctly.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
