95 f250 7.3 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-07-2014, 07:32 PM Thread Starter
95 f250 7.3
Less than 200k
New flywheel, clutch, drums /shoes, batteries, heat works, and air is ice cold.
3" Down Pipe with megaflow flow exhaust. It has fuel leak in the valley of motor. He replaced lift pump. He selling it for 5k so i might sweep it up
Matticus is offline
post #2 of 4 Old 01-07-2014, 09:33 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Ok, is there a question here? Are you telling us about it with no piks? Click the wrong button? What's up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 01-07-2014, 10:03 PM Thread Starter
Lol my bad I hit post instead of save draft. I was wondering what to look for?. I think fuel in valley be a line or a weephole on the pump?
Matticus is offline
post #4 of 4 Old 01-08-2014, 01:26 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
there are all kinds of things in the valley that can leak fuel orings on the fuel bowl, sensors of the fuel bowl, three rubber lines to the fuel pump, weep hole on the fuel pump, crush washers at the banjo bolt, the metal line under the turbo.
as for what else to check check the turbo for pitting, check for blowby with the oil cap test, test the steering to see if it is loose, check the radiator support and oil pan especially and the whole truck for rust. auto check the fluid for signs of over heating/burnt smell. make sure it goes through all gears like it should, manual check the clutch bushing for wear. if the seller will let you pull the inspect cover and look at the flywheel if it is a dual mass flywheel. check u joints for slop make sure th 4x4 works if it is 4x4. that's all i can think of now.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
