Injectors - Ford Powerstroke Diesel Forum
Old 09-24-2008, 09:07 PM
Injectors
Does anyone know what would be the easiest way to find out if i have spilt shot injectors or single shots i have a 97'
Thanks, Dorn
Old 09-24-2008, 09:13 PM
u have single shots if it is an obs
Old 09-24-2008, 09:33 PM
the only real way to find out if you have split shots is to pull the valve covers and check the codes. on the other hand if you have a California emissions sticker on the passengers side valve cover and a diaphragm looking thingy ( not so technical term, someone should be able to give you an accurate description soon) attached to the HPOP.
