How's this look? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-06-2014, 04:39 PM Thread Starter
How's this look?
So i've been looking for an obs ford for a while now and I always come back to this one. I know its not perfect but for my first i have to problem with putting some money into it here and there. But does is look solid? Also ive never driven a manuel diesel, also auto.
http://nwct.craigslist.org/cto/4177456508.html
delifresh is offline
post #2 of 16 Old 01-06-2014, 04:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Other then the flat bed srw it looks pretty good
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 16 Old 01-06-2014, 05:00 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Doesn't look too bad for the money. The problem is, why has it been for sale for so long?
I see Rotted drivers cab corner and door. Which means the radiator support is GONE and they are getting HARD to find(can't buy them new). Also that means the fenders are probably rotten too.
the oil leak can very will be from a rotten oil pan. In order to replace it , you need to pull the engine(costly)
Just some food for thought
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 16 Old 01-06-2014, 05:58 PM Thread Starter
Also can get it for around 4000
post #5 of 16 Old 01-06-2014, 06:11 PM Thread Starter
would the oil leak off the shock tower be from the oil pan?
post #6 of 16 Old 01-06-2014, 06:21 PM
I think the post means "Needs rear shock tower AND has a small oil leak."
I'd be VERY wary of rust. Finding rot free body panels will eat a hole in your wallet pretty fast.
williameub is offline
post #7 of 16 Old 01-06-2014, 06:49 PM
theforeman57's Avatar
Quoted: 4 Post(s)
well, look at it this way. it has the 5 speed, no need to swap. gauges ~300 $, single mass flywheel ( assuming since 400 hp clutch), d60 swap ~ 800-1000?$, factory alcoas $. so you already have the major downfall of the 250 taken care of, and if you do not like the bed sell it and get a pickup bed.
Id say go for it, especially if you knock him down to four grand.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #8 of 16 Old 01-06-2014, 07:21 PM Thread Starter
that only leaves the rust/rot
post #9 of 16 Old 01-06-2014, 07:23 PM
How much are alcoas worth now-a-days?
post #10 of 16 Old 01-06-2014, 07:31 PM Thread Starter
The guy says it doesnt leak from the oil pan but the valve cover gasket leaked about 2 qts every 5000 miles when the oil was changed.
