Glow Plug Relay wiring question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-06-2014, 05:32 AM Thread Starter
derek18105's Avatar
I have a 97 F250 4x4 with a plow. I didn't install the plow or its wiring so I am unsure if it is done right.
My glow plug relay (that i replaced last year) is shot again. Its smoking and only putting .88 volts through. I was going to replace it with the Stancor 586-902. But my main question is with the wiring. The larger cable that supplies power to the relay is connected to another relay on the passenger fender. Is this correct? Or should it go right to the positive side of the battery?
Its -40 with windchill out here and its not starting with it being plugged in and a battery charger in 200amp start mode on it. Im letting it charge a little more (@50amps) and then will go out and jump the relay and see if that will do it.
Also, are there any local places that carry the Stancor relay or do I need to order that online?
Thanks ahead of time
1997 Ford F250 7.3L 4x4 Auto
Mods: 6637 Air Intake
MBRP DP & 4" Exhaust
TS Perfomance Chip
derek18105 is offline
post #2 of 3 Old 01-06-2014, 08:33 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Yes, it is supposed to be connected to the relay on the fender. At that relay it is on the non-switched battery side of the relay. If you feel that you are going through relays fast test all the wiring from the GPR back to the battery. If there is a bad supply wire the GPR will be pulling extra amps to compensate. This will pop the GPR sooner then intended.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 01-07-2014, 03:05 AM
nra1ifer's Avatar
As for the relay.. unless you just LIKE to spend lots of money, the Western Plow 56131K is a very good, cheaper (price-wise) relay. $14.99 at Russo Power.
Deprecated Browser Error <<<<<< whatever that means.....IDK..... but it takes you to Russo's site
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
