gelled fuel question - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-05-2014, 05:01 PM Thread Starter
twitchcvma's Avatar
'97 Stroke....I put Diesel Kleen winter formula with anti gel in every fill up beginning in October. EVERY FILL UP. A couple weeks ago here in Colorado it got real cold. At night 0 to -8 and highs in the low to mid 20's. Never had a problem. Plugged her in at night and even at work. Last night it was around 0. She was plugged in. i went to get an alignment and she just stopped. Got a push to the mechanic. I checked the fuel bowl and everything was liquid. He said the fuel gelled. Now what the hell? If I put anti gel in the fuel every time I get fuel and it still gels, what can I do so this doesn't happen again? Were the stars simply aligned properly? Did my flux capacitor not work? thanks, guys. I appreciate it
Twith
twitchcvma is offline
post #2 of 13 Old 01-05-2014, 05:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The stuff is to help with gelling, it's not and end all super thing, a tank heater is honestly the most perfect thing for that situation
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 01-05-2014, 05:15 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Plugging in doesn't help the fuel, just the motor.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 13 Old 01-05-2014, 05:19 PM
m j
that doesnt seem cold enough to gel.
where did you buy the summer fuel from?
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #5 of 13 Old 01-05-2014, 05:27 PM
977300's Avatar
We got 10 inches of snow today and my block heater has created a dry spot by the antennae. From the warm heater box. I would think that between the pump and filter housing being in the valley, power service in the fuel system and the fuel bowl heater it would be hard to gel a 7.3
97 F-Super Duty 5 speed...T&S Performance Chip. More upgrades to come.
95 F-Super Duty 5 speed. The current project.
94 Dodge 2500 SOLD!
94 Dodge 3500 Sold to buy Superduty parts
95 Dodge 3500 Sold to buy more Superduty parts.
03 Dodge 3500 SRW, 4 door, 4X4, Cummins
Banks exhaust. Transmission upgraded.
977300 is offline
post #6 of 13 Old 01-05-2014, 05:32 PM
977300's Avatar
And the turbo in close proximity to the pump.
94 Dodge 2500 SOLD!
977300 is offline
post #7 of 13 Old 01-05-2014, 05:34 PM
jesilvas's Avatar
Quoted: 3 Post(s)
You have two big fuel tanks that are NOT by the heater. So it'll crank at first but then not be able to suck anything up and run dry.
An electric pump could circulate that warm fuel but that little warm fuel wouldn't do much for all the gelled fuel, I wouldn't' think.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 13 Old 01-05-2014, 05:55 PM
977300's Avatar
No, gelled is gelled. Takes a lot of heat if the tanks are the problem.
94 Dodge 2500 SOLD!
977300 is offline
post #9 of 13 Old 01-05-2014, 06:46 PM
leojr's Avatar
Quoted: 4 Post(s)
Trouble shoot it as if gelled fuel was not the problem. Replace the CPS? Tach move when you crank the starter? White smoke during cranking? Etc.
The way I read your first post, you are assuming the mechanic was correct that the fuel was gelled...where is it gelled? Because if he could tell you that you would know where to apply the heat. I suspect he can't... You don't have a gelled fuel problem. You just have a problem...and it is very cold outside, two separate issues.
m j likes this.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #10 of 13 Old 01-05-2014, 07:03 PM
m j
well said. I tried to type that a few times
if fuel is gel at only -17C you need to buy fuel elsewhere
m j is offline
