Sagging springs - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-05-2014, 09:44 AM Thread Starter
sandrock1's Avatar
Sagging springs
I have a 97 f250 and it sits lower on the drivers side mostly in the back. My guess is weak leafs on the rear on that side. I was wondering if I could put stronger springs on it to make it stronger in the back and possibly lift the rear up a bit. The truck is lifted but i was just wondering if anyone had any suggestions on what I should do. Thanks.
sandrock1 is offline
post #2 of 13 Old 01-05-2014, 10:36 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check for broken springs, also how old are your shocks? SD b codes are a popular replacement
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 01-05-2014, 11:03 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
funny my truck has the same problem with the same spring, no broken leafs checked that. had that spring re arch to pick up the lost height, reinstalled and been fine for 4 years
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 13 Old 01-05-2014, 11:03 AM Thread Starter
sandrock1's Avatar
I quickly checked for cracks in the leafs but did not find any. I should clean them off real well and look at them closer though. For the shocks I honestly can't say because I just bought the truck. All I know is that they are rough country and they are definitely at least 5 years old I'm sure more though. I'm guessing due to the amount of rust on them. But would a blown shock make it sit low on that side? It sits about 2 inches lower.
post #5 of 13 Old 01-05-2014, 11:10 AM Thread Starter
sandrock1's Avatar
And when I lift it with a jack, the side that is higher comes up way before the sagging side, even when I have the jack 3/4 of the way on the sagging side. I have even done this with empty fuel tanks because the front tank is on the side that is sagging. There just feels like there is more up and down play in the sagging spring.
post #6 of 13 Old 01-05-2014, 11:11 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Should have it re arched like terry, seems as though it's become weak
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 13 Old 01-05-2014, 11:15 AM
the baconator
Quoted: 149 Post(s)
bad bushings? mine was about 1.5 inches low on the drivers side
post #8 of 13 Old 01-05-2014, 11:26 AM Thread Starter
sandrock1's Avatar
I'm glad you guys said re arched because I never really knew that you could do that. As far as the bushings, I checked for play around the bushings but they look solid. And plus I did just put new shackles and hangers with bushings in the rear.
post #9 of 13 Old 01-05-2014, 11:27 AM Thread Starter
sandrock1's Avatar
At this point I'm pretty confident that they are just weak.
post #10 of 13 Old 01-05-2014, 06:31 PM
dr.deere's Avatar
Quoted: 19 Post(s)
My 94 is the same way no cracks been looking for springs just got my d60 in and the whole truck leans to the left and rear left real bad when I hook up to the gooseneck have new shocks coming to put on prob won't help and will be looking for either new or getting reached
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
