Common obs Leaks in engine valley - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-04-2014, 07:53 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
Recently bought a 97, and the valley of the motor is very greasy. I very recently had my drive way paved and don't want a leaky truck.
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 2 Old 01-04-2014, 08:10 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Well the sky is the limit here. Anything on the high pressure oil system could leak. Anything on the fuel system could leak. Anything on the turbo could leak. Gotta remember these are rubber o rings that have been in service for almost 20 years. Its gonna happen. First thing I would do personally is put new rubber lines on the fuel bowl or do e fuel if you can. That helps clear a lot of things. The turbo pedestal o rings are a good source of leaks but dont dig unless you need to. Only reason I mention the fuel bowl is its in the way to see the oil leaks so its good to pull out and clean with it out
Trucks and parts............
kanuck15 is offline
