extended brake lines?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-04-2014, 06:36 PM Thread Starter
im about the purchase a 4in rough country for my 95 powerstroke , and was wondering if i was goin to need extended brake lines for the front?
RushFORD is offline
post #2 of 6 Old 01-04-2014, 07:14 PM
Quoted: 85 Post(s)
Feedback Score: 4 reviews
Most likely yes if yours are the 15" ones. Napa sells oem style 18" front brake hoses for a 94 f350 iirc. That is what I installed on mine.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 6 Old 01-05-2014, 06:16 PM
leojr's Avatar
Quoted: 4 Post(s)
I saw my stock F250 lifted by the frame and wheels removed while the wheels were balanced and was shocked at how tight the stock brake lines were. I quickly installed a 3 line set made by Crown but I'm sure there are plenty of options.
I do plan on a mild lift so this needed to happen anyway. But after seeing how tight the stock length lines were, I'd change to a longer length if a replacement was needed.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #4 of 6 Old 01-05-2014, 06:22 PM
m j
which part number? my truck uses the brake lines as limit straps too
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #5 of 6 Old 01-05-2014, 06:59 PM
leojr's Avatar
Quoted: 4 Post(s)
I bought them through "CT Performance", I believe a regular here. I just told him my plans and he took care of the number crunching.
Denton, TX
leojr is offline
post #6 of 6 Old 01-12-2014, 06:08 AM Thread Starter
thanks for the replies guys. I see on rough country they got a set of front lines for 40 bucks. But they're only coming up with ones for 150s and broncos. Do you think they use the same fitting at the caliper as the 250s bc i no the brake line size is the exact same.
Extended Front Brake Lines for 80-96 Ford F-150 Pickup, Bronco [89310] | Rough Country Suspension Systems
RushFORD is offline
