leaking oil cooler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-04-2014, 10:53 AM Thread Starter
toad's Avatar
Quoted: 17 Post(s)
leaking oil cooler
So my oil cooler is leaking oil. Am I better to just replace it or reseal. My only concern about resealing it is the built up gunk that is more than likely inside of it.
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #2 of 5 Old 01-05-2014, 07:08 AM Thread Starter
toad's Avatar
Quoted: 17 Post(s)
anybody???
toad is offline
post #3 of 5 Old 01-05-2014, 06:09 PM
Micko's Avatar
Quoted: 4 Post(s)
If you think it is clogged then replace it vs. cleaning. The oil side is finned and hard to clean fully. Disturbing it could put crud back in your lubrication sys.
Micko is offline
post #4 of 5 Old 01-05-2014, 06:24 PM
m j
I did mine the inside looked amazingly clean.
I would buy the seal kit, inspect it while you have it out, if its nasty either clean or replace
I think an oldschool hot tank would get it clean
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #5 of 5 Old 01-08-2014, 02:46 PM
Quoted: 3 Post(s)
Mine looked extremely clean inside as well. I'd try a reseal kit. It's a common fix.
Airstreamer67 is offline
