superduty seats fitment - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-03-2014, 05:50 PM Thread Starter
will the seats out of a regular cab superduty fit in my regular cab OBS? looking to get rid of my bench for a set 40/20/40 flip console seats.
tony0713 is offline
post #2 of 5 Old 01-03-2014, 06:17 PM
Not Far From Par's Avatar
IIRC SD seats will fit if you bend the tab on each side...
Do a search.. I think there are lots of topics on the conversion
2006 F350 CCSB
Toreador Red & Silver
Dove Leather
ALL STOCK (for now)
Not Far From Par is offline
post #3 of 5 Old 01-04-2014, 07:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The sd seat is wider and longer, you may be a little closer to the dash then normal once installed
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 01-10-2014, 04:48 PM
I put a 08 bench in my reg. cab 95. It's definitely wider to the doors but I didn't notice a big difference on seat bottom width. All I did to fit it was center it drill new holes, use good hardware,done. I'm 5'8" the only seating difference I felt was that I was sitting up a lil higher which is nice. The superduty seat is tons more comfy than the original and definitely a good upgrade. If there is one drawback it's not having the ability to lean the seat back like u could in a superduty.
flathead239 is offline
post #5 of 5 Old 01-13-2014, 02:24 AM
ja9788's Avatar
OP I have the 40/20/40 F150 grey cloth seats in my 95 RC. Previous owner installed them but just going off of looks, seems pretty straight forward. A few extra mounting holes here and there. Sits up a few inches higher and way more comfortable than the stock seats.
< Joel >
95 F350 SCLB 4x4
- WW2
- 3" DP to 4" Straight pipe
- IDM 140v Mod
- TS 6 Pos.
- K&N Intake
- Glowshifts....
ja9788 is offline
