Torquing injectors - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-03-2014, 04:45 PM Thread Starter
Torquing injectors
I've read where it's a good idea to check the torque on the injector bolts.
Which bolts?
clint_ives is offline
post #2 of 6 Old 01-03-2014, 07:14 PM
PSDTV21's Avatar
The hold down bolts located at the top and bottom. 8mm IIRC
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #3 of 6 Old 01-04-2014, 08:02 AM
Ranzan's Avatar
Quoted: 20 Post(s)
yep good idea for sure i had to replace a few orings after i installed new injectors 3 out of the 8 slacked off after 4000k
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #4 of 6 Old 01-04-2014, 08:47 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Honestly they both need checked but only the top can be removed with the injector still in there
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 01-04-2014, 09:43 AM
m j
you mean bottom?
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #6 of 6 Old 01-04-2014, 09:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
One of them lol, thanks for correction, one of the bolts is for allignment
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
