Unplugging map sensor
Does unplugging the MAP sensor do anything negative to the truck???
will kick on the ses light
nothing neg just your cel will be on. and it gives you a little more power and smoke. you can get a boost fooler and no light will come on.
it messed my truck all up, it did not like it...
thanks alot may try it tomorrow
keep an eye on the egts
it will set a code. If the truck runs better, the map sensor is bad, replace it! with the map sensor unplugged, the ecm uses a default program. Its not supposed to run better on the default program, but if it does..... bad map. The map sensor itself wont set a code!
